Tuning a Trumpet for Cold Weather Performance
  • Thread starter Thread starter crosbykins
    Instruments Tuning
When a trumpet tuned in warm conditions is taken outside into cold weather, the sound produced will be affected due to the slower speed of sound in colder air. The frequency of the notes played will decrease, resulting in a lower pitch. This is because the relationship between sound velocity (v), frequency (f), and wavelength (λ) indicates that a reduction in speed leads to a reduction in frequency when the length of the trumpet remains constant. Therefore, musicians should expect their trumpet to sound lower when performing in cold conditions. Understanding this acoustic principle is essential for optimal performance in varying temperatures.
crosbykins
A trumpet is essentially an open air column. Assuming that it is tuned inside a warm building. When it is taken outside for a parade on a cold day, what will happen to the sound from the instrument?
-so outside the air is colder so sound travels slower...that's really all i have, help please! thanks in advance! :)
There is a formula that tells you the frequency of the note produced in terms of v and the wavelength. You know that v will be less, and assuming the length of the tube doesn't change significantly (and thus the wavelength), you can work out what happens to the frequency.
Do you know this formula relating v, f and λ?
-so, f = v/lambda, since v is less than f will also be smaller, lower f means a lower pitch, so the instrument will produce lower sound...is that right
*thanks for the help:smile:
That's a correct deduction. :)
thanks for the help!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
