Integral form of Particular solution question
rohanlol7
I'm fine with the first part. Part b) is causing me trouble
http://imgur.com/xA9CG5G
I tried subbing in the solution y1 into the given equation, but I'm not sure how to differentiate this, i thought of using integration by parts, Maybe i could guess the form of the solution, but so far I can't seem to get anything close to what is required
Hi rohanlol7:
Given an integral of the form
Y(x) = ∫0x y(x)dx​
dY(x)/dx = y(x).
Hope this helps.
ADDED
Sorry. I was careless reading the problem. Dicks' post should help.
Regards,
Buzz
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
