Integral involving hyperbolic functions
DryRun
Find \int \frac{x}{\sqrt{2x^2-2x+1}}\,dx
The attempt at a solution
First, i complete the square for the quadratic expression:
2x^2-2x+1=2((x-\frac{1}{2})^2+\frac{1}{4})
\int \frac{x}{\sqrt{2x^2-2x+1}}\,dx=\int \frac{x}{\sqrt 2 \sqrt{(x-\frac{1}{2})^2+\frac{1}{4}}}\,dx
Using substitution: Let (x-\frac{1}{2})=\frac{1}{2}\sinh u
I eventually get this expression, after integrating:
\frac{1}{2\sqrt 2}(\cosh (\sinh^{-1}(2x-1)+\sinh^{-1}(2x-1))
But i don't know how to simplify this any further, without getting a complicated answer. The final answer is: \frac{\sinh^{-1}1}{\sqrt 2}
hi sharks! :smile:
(you haven't said what the limits are)
cosh(sinh-1x) = √(x2 + 1) :wink:
(btw, you could have simplified the original integrand by rewriting the numerator as x - 1/2 + 1/2 :wink:)
Hi tiny-tim! :smile:
Congratulations on your PF award!
Doh! I forgot to include the limits.
\int^1_0 \frac{x}{\sqrt{2x^2-2x+1}}\,dx
If i evaluate over the limits:
Indeed, i get the answer!
I am trying to understand your suggestion:
\cosh (\sinh^{-1}x) = \sqrt{(x^2 + 1)}
It's too complicated to prove? I can't get the R.H.S. from the L.H.S.
Here is where I've reached...
\frac{x^2+x\sqrt{x^2+1}+1}{x+\sqrt{x^2+1}}
if y = sinh-1x
then x = sinhy,
so √(x2 + 1) = √(sinh2y + 1) = coshy = cosh(sinh-1x) :smile:
(if you think about it, this is obvious! :wink:)
I have also tried to solve this problem using your other suggestion - rewriting the numerator as x - 1/2 + 1/2, and i was able to get the answer.
Thank you for your insightful suggestions, tiny-tim. :smile:
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
