Integral of a concave function
talolard
Let f:[0,2]\rightarrow[0,\infty) be continuous and non negative. Assume thaqt for any x,y\in[0,2] and 0<\lambda<1 f(\lambda x+(1-\lambda)y)\geq\lambda f(x)+(1-\lambda)f(y). Given that f(1)=1 prove
\int_{0}^{2}f(x)dx\geq1
I've sat for hours. I have zero inspiration. I need a gentle shove in the right direction please.
Consider the function g(x)=x for x in [0,1] and g(x)=2-x for x in [1,2]. Can you show f(x)>=g(x)?
I think i got it.
Define g(x):\mathbb{R}\rightarrow\mathbb{R} . Such that g(x)=\begin{cases}<br /> x &amp; 0\leq x\leq1\\<br /> 2-x &amp; 1&lt;x&lt;2\end{cases}.
Assume that for some x\in[0,2] g(x)&gt;f(x) . Then g(x)=x&gt;f(x)=f(x1+\left(1-x\right)y)\geq xf(1)+\left(1-x\right)f(y)=g(x) +Something positive (Not precise here with the domain).
Then g(x)\geq g(x)+\epsilon a contradiction. Thus we have that for all x\in[0,2] f(x)\geq g(x)
Then \int_{0}^{2}f(x)\geq\int_{0}^{2}f(x)=\int_{0}^{1}x+\int_{1}^{2}2-x=\frac{1}{2}+\left|2x-\frac{x^{2}}{2}\right|_{1}^{2}=\frac{1}{2}+4-2-2+\frac{1}{2}=1 Q.E.D.
I can't really figure out what your contradiction is all about. Did you draw a graph of g(x)? You know f(0)>=0 and f(1)=1. If you connect (0,f(0)) and (1,f(1)) with a line then your condition says the graph of f is above or on that line, right? Do you see how that proves f(x)>=g(x) on [0,1]? Can you translate the picture into a proof?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
