Integral using partial fractions
manenbu
\int \frac{xdx}{x^3-1}
Having difficulties with this one.
I managed to break it down to two partial fractions, being x-1 and x^2+x+1 but couldn't make anything out of it.
Yes, x3 - 1 = (x - 1)(x2 + x + 1), but what did you get for your partial fractions? They should look like this:
\frac{A}{x - 1}~+~\frac{Bx + C}{x^2 + x + 1}
You should have/will need to find the values for A, B, and C.
Sorry, forgot.
I ended up having this:
\frac{1}{3} \int \left(\frac{1-x}{x^2+x+1} + \frac{1}{x-1} \right)dx
the right part is easy, it's ln|x-1|, but the left part is what's bothering me. Tried completing the square, separating it into 2 different integrals, nothing helps.
\left(\frac{1-x}{x^2+x+1} \right)
=~(-1/2)~\frac{(2x - 1) - 1}{x^2 + x + 1}
Now split this up into two fractions, and integrate each. The first one you can solve by substition, with u = x2 + x + 1.
The second one is a little harder, as you will have to complete the square to get the denominator in the form (x + <something>)2 + <something else>. The idea here is that
\int \frac{du}{u^2 + a^2}~=~(1/a)tan^{-1}(u/a) + C
You had a small mistake here, it should be (2x+1)-3 and not (2x-1)-1.
But thanks! It helped me solve it.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
