Integration by partial fractions, #2
Xcron
This next problem is rather strange and it once again involves quadratic factors and I am not able to get the correct answer.
The problem is:
\int \frac{7x^3-3x^2+73x+53}{(x-1)^2(x^2+25)}dx
Step I:
7x^3-3x^2+73x+53 = A(x-1)(x^2+25)+B(x^2+25)+(Cx+D)(x-1)^2
I easily get the value of B by plugging in 1 for x and it turns out to be 5. After that I organize all of the degrees and the right side and use the method of equating coefficients, but that turns out to be an extremely tedious monster which leads me to the wrong values for coefficients.
Any help/advice would be appreciated.
Just because x=1 is the only real root of the denominator, doesn't mean you can't just plug in other values of x to solve for other variables, e.g. use x=0 or x=431 or x=whatever. If you know how to use complex numbers, you should plug in x=5i and x=-5i.
Xcron said:
The problem is:
Step I:
A=3, B=5, C=4, D=3
and thus
\int \frac{7x^3-3x^2+73x+53}{(x-1)^2(x^2+25)}dx = -\frac{5}{x-1}+3\ln (x-1) + 2\ln (x^2+25) +\frac{3}{5}\mbox{arctan} \left( \frac{x}{5}\right)+C
I used Maple.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
