Integration by Parts: Showing $\int x^3 e^x^2 dx = e^x^2 ( \frac{ x^2 -1}{ 2 })$
Ed Aboud
Show using integration by parts that:
Integration by parts obviously.
\int u dv = uv - \int v du
Let u = x^3 and dv = e^x^2 dx
\int x^3 e^x^2 dx = \frac{x^2 e^x^2}{ 2 } - \frac{3}{2} \int x e^x^2 dx
Now use integration by parts again on \int x e^x^2 dx
And I get :
\frac{e^x^2}{ 2 } - \frac{1}{2} \int \frac{1}{x} e^x^2 dx
This really leaves me no closer again because I have to use integration by parts again on
Any suggestions on what to do.
Thanks for the help.
You mean e^(x^2). Your superscript isn't coming out. On the first step, you can't pick dv=e^(x^2)*dx. You can't integrate that. I have no idea what you are doing after that. Try dv=x*e^(x^2)*dx and u=x^2 for a first step. When you get to xe^(x^2), don't do parts again. Do it by an easy u-substitution (the same one you used to integrate dv).
I don't think this is a very good choice for your u and dv, because v=\int dv=\int e^{x^2} dx is not e^{x^2}...try a substitution of the form w=x^2 before applying integration by parts :wink:
Cool, I showed it.
Thanks for the help!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
