stephenkeiths
- 53
I'm trying to evaluate the integral
I(a)=\int\frac{cos(ax)}{x^{4}+1}
from 0 to ∞
To do this I'm going to consider the complex integral:
J=\oint\frac{e^{iaz}}{z^{4}+1}
Over a semi-circle of radius R in the upper half plane, then let R-->∞
There are 2 curves, the straight curve along the real axis, and the semi-circular arc.
Along the first curve (along the real axis) the line integral is just
I_{1}=\int\frac{e^{iax}}{x^{4}+1}
from 0 to infinity
Now the real part of this is 2*I(a)
The second line integral goes to zero. So 2*I(a)=Re(J).
So I need to evaluate J by residue calculus and take the real part to get I(a).
So there are 2 simple poles inside of the semi-circle, namely
z=e^{i\frac{\pi}{4}} and z=e^{i\frac{3\pi}{4}}
So J=2i\pi(Res(f,e^{i\frac{\pi}{4}})+Res(f,e^{i\frac{3\pi}{4}}))
But I'm having trouble computing the Residues.
I know that Res(f,e^{i\frac{\pi}{4}})=\frac{e^{iaz}}{4z^{3}} z=e^{i\frac{\pi}{4}}
But I'm struggling with the exponential to an exponential, I can't get a "clean" answer. I'm not sure if there's a better way I should go about this. Or if there's something I'm doing wrong.
Please Help!
