Integration by substituition question.
  • Thread starter Thread starter misogynisticfeminist
    Integration
The discussion revolves around the integration of the function ∫(x^3/√(x^2 - 1)) dx using substitution. The original poster's approach led to a different final answer than the one provided in the textbook, prompting a request for clarification on the mistake. Other participants confirmed that the poster's answer is correct but can be rearranged to match the textbook's format. A suggestion was made to verify answers by taking derivatives to ensure accuracy. The conversation also touched on the potential for grading leniency regarding different forms of correct answers.
I'm able to do this question but my answer is different from that in the book.
\int \frac {x^3}{\sqrt{ x^2 -1}} dx
what I did was to take the substituition u= (x^2-1)^1^/^2
so, x^2 -1 = u^2
x^2 = u^2+1
x= (u^2+1)^1^/^2
x^3= (u^2+1)^3^/^2
dx= \frac {1}{2}(u^2+1)^-^1^/^2 (2u)du
dx= u(u^2+1)^-^1^/^2 du
\int \frac {x^3}{\sqrt{ x^2 -1}} dx= \int \frac {(u^2+1)^3^/^2}{u} . \frac {u}{(u^2+1)^1^/^2} du
which simplifies to,
\int u^2+1 du
\frac {1}{3} u^3 +u+C
\frac {1}{3} (x^2-1)^3^/^2 + (x^2-1)^1^/^2
that's my final answer but the book gave,
\frac {1}{3} (x^2+2)\sqrt{x^2-1}+C
where does my mistake lie?
Are you sure your answer is not the book's answer?
Yap,it's the same "animal".It's just the fur is a little shady...
Daniel.
if your ever unsure of your answer ...you can always take the derivative of your answer and see if you get the integrand.
your answer is fine... you need one more step to get the text answer
= (x^2-1)^1^/^2 (\frac {1}{3}(x^2-1) +1)
= (x^2-1)^1^/^2 (\frac {1}{3}x^2-\frac {1}{3}+1)
= (x^2-1)^1^/^2 (\frac {1}{3}x^2+\frac {2}{3})
\frac {1}{3} (x^2+2)\sqrt{x^2-1} :
Isn't y^(3/2) = (y)(y^(1/2)) ? Rearrange and simplify what you've got and it should come out the same.
EDIT : NM, Vincent has shown the working
hey thanks, that's a very good tip !
I am wondering if the answer which I gave is in a different form from the one in the answer script during an exam, will I be penalised?
Unless your teacher is a narrow minded s.o.b.,i don't see why.If i were u,on this integral i would have gone for another substitution,using hyperbolic sine and cosine.
Daniel.
