Integration by trigonometric change of variable
MMM
I'm trying to solve ##\int\sqrt{a^2 - x^2}##
by using the substitution ##x = asin\theta##
##x = asin\theta
##y = \int\sqrt{a^2 - a^2cos^2\theta}##
##y = a\int\cos\theta##
##y = a^2\int\cos(\theta)^2##
##y = (a^2)/2 * \int1+cos2\theta##
##y = a^2/2 + a^2/4 * sin2\theta\ + C##
##\theta = arcsin(x/a)##
##a^2/2 * arcsin(x/a) + a^2/2 * sin\theta\cos\theta\ + C## Any help would greatly be appreciated.
The answer in the book is ##(a^2/2) * arcsin(x/a) + (x/2) * \sqrt{a^2 - x^2} + C##
EDIT: I figured it out.
##x = asin\theta
You have some crazy algebra happening there. You are not ready for tests or exams yet because your working out is incorrect. It must be neat and each statement must follow from the previous one. For example, this is meaningless: ##y = a \int cos\theta##, that is not how an integral is written.
You have started off by copying the problem wrong. It should be ##\int\sqrt{a^2- x^2}dx##
Do you see the difference?
##x = asin\theta
Same mistake as before.
I have not idea where you got this, \sqrt{a^2- a^2 cos(\theta)} is NOT equal to &quot;a cos(\theta)&quot;<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> ##y = a^2\int\cos(\theta)^2## </div> </div> </blockquote> And this is definitely not equal to the previous line!<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> ##y = (a^2)/2 * \int1+cos2\theta##<br /> ##y = a^2/2 + a^2/4 * sin2\theta\ + C##<br /> ##\theta = arcsin(x/a)##<br /> ##a^2/2 * arcsin(x/a) + a^2/2 * sin\theta\cos\theta\ + C## Any help would greatly be appreciated.<br /> <br /> The answer in the book is ##(a^2/2) * arcsin(x/a) + (x/2) * \sqrt{a^2 - x^2} + C##<br /> <br /> EDIT: I figured it out. </div> </div> </blockquote>
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
