Integration of composite derivative of function
Bonaparte
While I was in school I thought to see what a function whose derivative is always perpendicular to another functions derivative would look like, so for example for X^2 we have -ln(x)/2.
Well all those integration tables I guess
Obviously their product is -1, so if were looking for g(x),
g(x) = ∫(-1/f'(x))dx
However, I don't seem to be able to integrate this.
I need to have a ln(f'(x)), who's integral is f''(x)/f'(x), but dividing by f''(x) or try to subtract it just makes things much tougher. This isn't homework, but it would be very nice if I was to be helped. Please don't give solution, just clue.
Thanks, Bonaparte
It sounds like you are looking for "orthogonal trajectories", a family of curves that are always perpendicular to another, given, family of curves.
Yes, to find the orthogonal trajectories of y= x^2+ c, where c is a constant, we differentiate to get y'= 2x and the constant has disappeared. Now, any curve perpendicular to that has y'= -1/(2x) and the integral of that is -(1/2)ln(x)+ C.
On the other hand, if the first family were given by y= cx^2, so that the constant is multiplied rather than added, y'= 2cx and to get rid of the constant we have to write y'/y= 2cx/x^2= 2/x so that y'= 2/(xy). Now to find the orthogonal trajectories, we look at y'= -2/(xy) so that yy'= -2/x or ydy= (-2/x)dx and, integrating (1/2)y^2= -2 ln(x)+ C.
But there is no general way to solve that problem for all x. It depends to much upon the specific f. "Orthogonal trajectories" is typically a subject for a "Differential Equations" course.
Could you explain how you got from 2cx/x^2 = 2/x? and then when you had y'/y=2/x, and multiplied both sides by y, how did you get 2/xy? should it not be 2y/x?
I actually thought you would have 2cx*g'x = -1, g'x=-1/2cx
gx = (-1/(2c))*ln(x)+C?
Thanks, Bonaparte
HofI meant to write y'/y= 2cx/(cx^2)= 2/x, so as you say, y' = 2y/x. For the orthogonals I get y' = -x/(2y), leading to ellipses.
Why is it not possible to deriviate 2cx and relate to c as if it is a constant? So you have y=2cx^2
y'=(2cx), g'=-1/(2xc), so g= ln((2xc)/-2c'+C, wouldn't this be the answer?
Thanks, you are all great :)
Bonaparte
It is only constant in regard to one of the original family of curves. A curve in the orthogonal family runs across these, so the set of intersections treats this as a parameter. Eliminating the constant, as HofI did, gets around this problem by extracting a general truth about the family as a whole.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
