Learn How to Integrate 2\pixe^{-4x} with Step-by-Step Guide | Homework Statement
  • Thread starter Thread starter alicia.kostka
    Integration
alicia.kostka
can someone please tell me how to integrate 2\pixe^{-4x}
(the Pi is not supposed to be superscript, don't know why it looks that way)
Use integration by parts.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
