Integration using Partial Fractions
Hootenanny
Staff Emeritus
I need to find the following intergral:
\int_{0}^{1} \frac{28x^2}{(2x+1)(3-x)} \;\; dx
So I split it into partial fractions thus:
\frac{2}{2x+1} + \frac{36}{3-x} - 14
Then integrated:
\int_{0}^{1} \frac{2}{2x+1} + \frac{36}{3-x} - 14 \;\; dx
= \left[ \ln\left| 2x+1 \right| + 12\ln\left| 2-x \right| - 14x \right]_{0}^{1}
But this isn't going to give me the correct answer which is quoted as:
37\ln 3 - 36\ln 2 - 14
Can anybody see where I've gone wrong? Thank's
Sorry just a correction in my answer:
= \left[ \ln\left| 2x+1 \right| + 12\ln\left| 3-x \right| - 14x \right]_{0}^{1}
Your partial fraction expansion is ok. However, you integrated \frac{36}{3 - x} incorrectly.
Ahh yes. Thank-you, I realize what I've done now.
Is there any standard intergral in the form of \int \frac{a}{b+x} = ... because at the moment I'm not sure what to do. If anybody could guide me through it?
I suppose you can use \int\frac{a}{b\pm x}dx=\pm a\ln|x\pm b|
- Kamataat
Thank you very much.
hi there, I was wondering if you could possibly help me with an integration problem
\int_{1/4}^{-1/4} \frac{1}{(1-4x^2)} \;\; dx
i managed to split it into partial fractions and hence split up the integration as follows
\frac{1}{2} \int_{1/4}^{-1/4} \frac{1}{2x+1} - \frac{1}{2x-1} \;\;dx
after this i integrated it in the following manner but I am unsure as to whether it is right, and if so, how to continue it.
[\frac{1}{2} (\frac{1}{2}\ln(2x+1)-\frac{1}{2}\ln(2x-1))]still between the same two limits
Can anyone offer a hand?
if my integration was correct please continue reading this post, if not then it doesn't matter!
I broke down that inegraton to read
[\frac{1}{2} \ln\frac{2x+1}{2x-1}] limits \pm\frac{1}{4}
i then simplified this down to the following (including limit values)
\frac{1}{2} \ln\frac{1.5}{-0.5} - \frac{1}{2}\ln\frac{0.5}{-1.5}
Using the rules of logs i calculated this to be
\ln\frac{-3}{\frac{-1}{3}}
Giving a final answer of \ln9
Does anyone know if this is the correct answer or have i gone about it in the wrong way?
The correct answer is
\frac{1}{4} \left(\ln|2x+1|-\ln|-2x+1|\right)
you need the absolute values in \ln(x) in order to be well defined.
See Kamataat's post \int\frac{a}{b\pm x}dx=\pm a\ln|x\pm b|
well you have \frac{1}{1-4x^2}
so it should become
\frac{1}{(1+2x)(1-2x)}
if you want to write it as (2x+1)(2x-1), then you have to factor out a negative
you have it the other way around, i even checked it on my calculator and my answer matches:
after integrating it should become
\frac{1}{4}\left[\ln\left|\frac{1-2x}{1+2x}\right|\right]_{.25}^{-.25}
thanks
