Internal Energy and kinetic friction
To determine the increase in internal energy of the block-surface system due to friction, the work done against friction must be calculated. The coefficient of kinetic friction is given as 0.300, and the applied force is 76.0 N at an angle of 20.0°. The normal force must be correctly calculated by considering all vertical forces acting on the block, as the vertical component of the applied force does not equal the normal force. The correct approach involves summing the vertical forces to ensure they equal zero, which will help in finding the accurate normal force. Understanding these concepts is crucial for solving the problem correctly.
hats_06
Please help, I've been struggling with this question for so long! We haven't done internal energy so I am not sure even where to really begin?
A 10.0 kg block is dragged over a rough, horizontal surface by a 76.0 N force acting at 20.0° above the horizontal. The block is displaced 3.50 m, and the coefficient of kinetic friction is 0.300.
What is increase in internal energy of the block-surface system due to friction?
The change in internal energy equals the work done against friction.
so if Ff= Uk.N...Then since Uk = 0.3 and N = 76.sin 20
So Ff = 7.8, Hence W = 7.8 x 3.5 = 27.3? I tried that answer but it didnt work :S
First you must correctly solve for the normal force. 76sin20 is the vertical component of the applied force, not the normal force.
To find the normal force, analyze all the vertical forces that act on the block. Since the block doesn't accelerate vertically, vertical forces must sum to zero. Hint: There are three forces acting on the block that have vertical components; the normal force is one of them.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
