How Do You Calculate EMF and Internal Resistance in a Circuit?
FlipStyle1308
Here is the question I need to solve:
A battery has an emf E and an internal resistance r. When the battery is connected to a 25 ohm resistor, the current through the battery is 0.75 A. When the battery is connected to a 53 ohm resistor, the current is 0.45 A. Find the emf of battery and its internal resistance.
Okay, so I have a feeling I will be using the equation V = IR, but I don't knnow how to incorporate an internal resistance into the equation or approach. Can someone please help me outline the steps to solve this? Thanks!
1. Treat the internal resistance as a resistor (r) in series with the battery (E).
2. Draw the circuit diagram for both cases.
3. Solve the two circuits - write down the two equations.
4. Solve for the 2 unknowns from the 2 equations.
Would you be able to explain a bit more for step #1? How would my equation(s) be set up?
You do not set up the equation until you have a circuit diagram. Once you draw the circuit as described in #1, you set up the equation using Kirchoff's voltage law (which is a fancy extension of Ohm's law): algebraic sum of all EMFs = algebraic sum of all voltage drops across resistors (these voltage drops calculated by Ohm's Law).
http://en.wikipedia.org/wiki/Kirchhoff's_circuit_laws
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
