How Do You Calculate Phase Difference in a Traveling Harmonic Wave?
To calculate the phase difference in a traveling harmonic wave with a frequency of 10Hz and a speed of 200m/s, the wave equation is essential. The phase difference can be determined using the formula Δφ = (2π/λ)Δx, where λ is the wavelength and Δx is the distance between the two positions. Given the speed and frequency, the wavelength can be calculated as λ = v/f, resulting in a wavelength of 20m. For two positions 3m apart, the phase difference can then be computed. Understanding these concepts is crucial for solving related physics problems effectively.
Craig
A traveling harmonic wave has a frequency of 10Hz and a speed of 200ms-1.
Calculate the phase difference at a given instant at two positions which are 3m
Hello Craig. Welcome to PF !
Do you have a question here?
What have you tried?
Where are you stuck?
I have a BSc in physics However that was 15 year ago and now I have a friend of my daughter doing summer school to get into uni and I'm helping. I am a bit rusty and need help
Can you write down the equation for a traveling wave?
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
