Inverse Trigonometric Equation problem
The discussion centers around simplifying the expression cos(arcsin x). The user initially struggles with the problem but receives guidance on using a right triangle to visualize the relationship between sine and cosine. By defining arcsin x as θ, they establish that sin(θ) = x, leading to the conclusion that cos(θ) = √(1 - x²) using the Pythagorean theorem. Clarifications are provided regarding the sign of the result, emphasizing that the answer is valid under the assumption that x is positive. Ultimately, the user confirms their understanding and expresses gratitude for the assistance received.
acen_gr
EDIT: 1.Homework Statement
The problem asks to simplify this: cos(arcsin x)
let arc sin x = θ
Hoping for some explanation. I really don't have any idea. Thank you so much in advance!
EDIT: I have to edit because I received a warning for not posting for #3 and #2. I originally posted "cos(arcsin x)" for #2 because that was what I know that is relevant to the problem. And I apologize for I didn't know it wasn't enough (I'm new here and sorry if I didn't understand the rules well, I thought it was okay to remove the format instructions and just put what is being asked instead. Quoted above is my previous post #3. As I said there, I really don't have any idea and therefore asks for some (can't put any attempt) When I got the hint from the mentors, I was able to work on this:
Let arcsin x = θ
if arcsin x = θ, then x = sinθ
get the cos of θ from given x/1 and should get for cosθ = √1-x2 (by pythagorean theorem)
the answer is cos(θ) = √1-x2
Let \theta = \arcsin(x) so then x=\sin(\theta). This expression is just simple trig where you first learn that the sine of an angle is OPP/HYP in a right triangle right? So do just that. Create the right-triangle with an angle of \theta such that \sin(\theta)=x (which is equivalent to x/1).
So what should be my final answer? Is it Cos θ? Sorry if I ask too many. :(
EDIT: Ok sir. Nevermind this. I already got the answer. Thank you so much! :)
Good! I am glad you were able to get the answer- I hope you were able to work it out for yourself from the hint acen gr gave you.
For others who might wonder: Yes, "the answer is cos(\theta)" but that is not the end of it. As acen gr suggested, "Create the right-triangle with an angle of θ such that sin(θ)=x (which is equivalent to x/1)." Then we have a right triangle with "opposite side" of length x and "hypotenuse" of length 1. By the Pythagorean theorem, the "near side" has length \sqrt{1- x^2}. Since cosine is "near side over hypotenuse", cos(\theta)= cos(cos^{-1}(x))= \frac{(\sqrt{1- x^2}}{1}= \sqrt{1- x^2}
You could also do it this way: for any angle \theta, sin^2(\theta)+ cos^2(\theta)= 1 so that cos(\theta)= \pm\sqrt{1- sin^2(\theta)}. That is, cos(sin^{-1}(x))= \pm\sqrt{1- sin^2(sin^{-1}(x))}= \pm\sqrt{1- x^2}. Because the standard domain of sin^{-1} is -\pi/2 to \pi/2, the sign is the same as the sign of x.
(The sign did not come up in the previous paragraph because being able to draw a triangle with side "x" assumes x is positive.)
HallsofIvy, I think you're getting a little mixed up with who is helping who :-p
Sir, so the final answer should be Cosθ = \sqrt{1- x^2}? Am I right?
EDIT: Anyway sir, I am the one who was helped by Mentallic :)
EDIT: How do I make square root symbol here?
One of these days, I really need to learn to read!
Assuming that x is positive, yes. Otherwise cos(sin(\theta))= \pm\sqrt{1- x^2}.
There is a LaTeX tutorial at https://www.physicsforums.com/showthread.php?p=3977517&posted=1#post3977517.
For just a single square root symbol, if you click on the "Go Advanced", you will see a table of "Quick Symbols" and there is a "√" there- notice that you had better use ( ) with that!
Wee! Thanks mentor! :) I love this site!
Yes that's correct.
You already have! Using tex tags as you've done.
Create a homework thread and I'm sure some of us would be delighted to help you :wink:
Just to clarify, we're talking about \cos(\sin^{-1}\theta) and not \cos(\sin\theta)
Also, the range of \sin^{-1}\theta is [-\pi/2, \pi/2] and thus the range of \cos(\sin^{-1}\theta) is [0,1] so the answer is only \sqrt{1-x^2}
Oh I see. No wonder why the actual question here in my notes asks for an exact answer;) Thanks Metallic! :D
