Magnesium Nitrate Formula: Mg(NO3)2
  • Thread starter Geekchick
  • Tags
    Ionic
In summary, the formula for magnesium nitrate is Mg(NO3)2, with the cation Mg+2 and two anions of nitrate (NO3) combining to form a neutral compound. The charges of -6 from the two oxygen atoms and -1 from the nitrate anion add up to -7, which is balanced out by the +2 charge of the magnesium ion. The subscript 2 indicates the presence of two nitrate anions in the compound.
Geekchick
77
Write the formula for magnesium nitrate.
2. The attempt at a solution
Okay, so I get that I have to list the cation first and then the anion. I also understand that I have to take the charges into consideration and end up with a neutral compound. My question is why is the formula for magnesium nitrate
Mg(NO3)2
If Mg+2 N-3 and O[tex]^{3}_{-2}[/tex] to me it seems that O would have a total charge of -6 add the N charge and that's -9 while Mg has just +2. So this doesn't seem to equal out, plus I don't understand where the subscript 2 is from.
Thanks for the help sorry if this is a simple question.
NITRATE has a charge of negative one;
Nitrate has a charge of -1.
Yes the oxygens each have associated charge of -2 each.
One Mg ion has charge +2, so it needs 2 nitrates.
Oh :blushing: thanks!
Could we put in a chart or a table in a message? Someone could clarify things like charge accounting for an ion very nicely using a table. I see no tags for creating a chart or table.
1. What is the chemical formula for Magnesium Nitrate?
The chemical formula for Magnesium Nitrate is Mg(NO3)2.
2. What is the molar mass of Magnesium Nitrate?
The molar mass of Magnesium Nitrate is 148.31 g/mol.
3. What is the state of matter for Magnesium Nitrate at room temperature?
Magnesium Nitrate is a solid at room temperature.
4. What are the common uses of Magnesium Nitrate?
Magnesium Nitrate is commonly used in fertilizers, fireworks, and as a component in the production of magnesium metal.
5. Is Magnesium Nitrate toxic?
Magnesium Nitrate can be toxic if ingested in large amounts, but it is generally considered safe when handled properly.
