Is g(x) = 1/(x^2+1) Concave Down on Which Intervals?
  • Thread starter Thread starter vmtyler
The discussion revolves around determining the intervals where the function g(x) = 1/(x^2+1) is concave down, focusing on the use of derivatives to identify concavity.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the necessity of finding the second derivative and whether to set it equal to zero to locate inflection points. There is confusion regarding the interpretation of the second derivative's sign on either side of these points.
Some participants have provided guidance on identifying inflection points and determining the sign of the second derivative. There is an ongoing exploration of the implications of these findings on the concavity of the function.
Participants mention the use of the quadratic formula and calculators, indicating a reliance on computational tools to assist in their analysis. There is also a reference to a textbook answer, suggesting a potential discrepancy between their calculations and the provided solution.
vmtyler
For what intervals is g(x) = 1/(x^2+1) concave down?
Quotient Rule
OK, so I have found the first and second derivative, but I am confused as to how I should use them to find where the function is concave down. Do I set the second derivative equal to zero? Use the quadratic formula? I know the answer from the back of the book, but my attemps to get the same answer have failed. Please point me in the right direction! Thank you :)
Setting the second derivative equal to zero will give you the inflection points, but you also need to determine whether the second derivative is (+) or (-) on each side of these inflection points...what are you getting for your solution?
Ok, so for the 1st derivative I have:
-2x/(x^2+1)^2
Second:
-6x^2-2/ (x^2+1)^2
Do I need to factor the denom? Also, you stated that I need to determine the values on either side of the inflection points, I should do that with my calculator, right? So, if I have this correct, determining the value (+ or -) of the function on both sides of the inflection points will tell if the original funtion is concave up or down?
Thank you!
Close, I get the numerator as being +6x^2-2... and you don't need to factor the denominator; the expression will only be zero when the numerator is zero...what does that give you for you inflection points?
WOW! You have been so much help!
I got
X= sqrt of (1/3)
So the function is concave down for all X values between -< X < + of sqrt (1/3)
I have been going crazy trying to figure this is out! Thank you for your time :)
No problem :smile:
  • · Replies 28 ·
