Is the answer in book wrong? Ones complement conversion
  • Thread starter Thread starter orangeincup
    Book
The discussion centers on converting the one's complement binary number 1000 1000 into its decimal equivalent. There is confusion regarding the sign representation, as the leading '1' indicates a negative value in one's complement. The correct interpretation reveals that the one's complement of the number is positive, leading to a final result of -119. The book's stated answer of 119 is incorrect for this context. Clarification is needed on the conversion process and the implications of the sign bit in one's complement representation.
orangeincup
Convert the following one's compliment binary into a decimal number
1000 1000
The book says the answer is suppose to be 119, but shouldn't it be negative? I thought one at the front of the number represented the sign, when using one's compliment.
It depends on how many bits are defined for the number like 8bits or 16bits...
In this case, it looks like it is a negative number so the ones complement of it will be positive because all bits are reversed.
So show your work and we can confirm what you got.
http://en.m.wikipedia.org/wiki/Ones'_complement
Likes 1 person
For positive numbers, the ones and twos complement representation of a value are the same. For negative numbers with the same string of bits, the ones complement value will be +1 more than the two's complement value. For 8 bit numbers, 10000000 is -128 in two's complement and -127 (= -128 + 1) in one's complement, 11111111 is -1 in two's complement and 0 (= -1 + 1) in ones complement, and 10001000 is -120 in two's complement and -119 (= -120 + 1) in ones compement.
Likes 1 person
1000 1000 represented by one's complement
My workings...
1 at the far right means it's negative
inverting numbers...
0111 0111
0+64+32+16+0+4+2+1=119
Answer: -119
The solution says it's 119. Here's exactly what the question asks for:
What is the decimal representation of 8 bit 1000 1000 (subscript 2) one’s
compliment numbers.
Ans: 119
