Is there a more efficient method for determining if the gas is heated or cooled?
  • Thread starter Thread starter Vibhor
    Gas
The discussion centers on analyzing the heating or cooling of gas using the ideal gas law and related equations. The initial analysis shows that when the volume of gas increases, the pressure decreases, indicating a drop in temperature unless heat is supplied. Participants agree that the internal energy concept isn't necessary for this problem, as it can be addressed through the ideal gas equation alone. Alternative approaches, such as substituting pressure into the equations, are suggested to simplify the analysis. The conversation emphasizes the relationship between volume, pressure, and temperature in gas behavior.
Vibhor
PV = nRT
##PV^2 = constant##
Differentiating both the sides we get , ##V^2dP + 2PVdV = 0 ##
Now , using this along with ##PdV+VdP=nRdT## , we get ## PdV = - nRdT ## .
Since ##dV## is positive , ##dT## is negative which means the temperature falls or gas is cooled .
Is this the correct way to analyze the problem ?
Thanks
Yes.
Likes Vibhor
Thank you .
Please check the attached image containing the official solution . Do you think the analysis done in it is correct ? I could not understand it .
Vibhor said:
Thank you .
For the same fractional increase in volume the final pressure is lower, so the temperature must have decreased rather than staying constant. It's equivalent to what you did mathematically, but I like the way you did it better.
A gas does positive work when it expands.
The internal energy is used for this resulting in a decrease in the gas's temperature, unless heat is supplied to cancel this.
When just enough heat is supplied to cancel this we get that Boyle's law is upheld, or put another way the gas is kept at a constant temperature by a heat source.
This means that the heat into the system is used to do the work or produce the expansion.
In this case the gas has to expand even more to keep the product constant (V2).
There is no need to invoke internal energy or the first law to address this problem. This can be done strictly as an ideal gas equation analysis.
Ok
Another approach is to substitute ##P = nRT/V## into ##PV^2 = ##constant to get ##TV = ## constant.
Likes Vibhor
Fantastic ! You made my work in OP look silly :-p.
