Is there a trigonometric identity for this ?
Usjes
Hi,
I am trying to figure out what the result is when adding two sinusoids of the same frequency but with different phase and amplitudes. Specifically I want to know if the result is always another sinusoid of the same frequency. For the case of the the same amplitude I have:
cos(wt) + cos(wt+phi) = 2.cos(wt+phi/2).cos(phi/2) ... this follows from the trig. identity:
cos(A)+cos(B) = 2.cos[(A+B)/2].cos[(A-B)/2]
So the addition of two sinusoids of the same frequency and amplitude will always give a sinusoid of the same frequency. What about the more general case:
cos(wt) + k.cos(wt+phi) where k is a constant. Will the result here also always be a sinusoid of frequency w ? Intuitively I think so, but I havn't been able to derive an expression for the phase and amplitude.
Does anyone know ?
Thanks.
Mathematics news on Phys.org
cos(wt) + k.cos(wt+phi)=-k sin(phi) sin(wt)+(k cos(phi)+1)cos(wt)
... and if you want, you can write any expression of the form
A sin(wt) + B cos(wt)
in the form
sqrt(A^2 + B^2)cos(wt + alpha)
where
tan alpha = A/B
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
