Is this correct without a direction in metres?
  • Thread starter Thread starter barthayn
    Direction
The discussion centers on calculating the direction and distance of a rocket-powered hockey puck moving on a frictionless table. At t = 2 seconds, the puck moves at an angle of 62 degrees from the x-axis, derived from the x-velocity of 16 cm/s and y-velocity of 30 cm/s. At t = 5 seconds, the puck's displacement from the origin is determined to be approximately 180.27 cm, calculated using the area under the velocity-time graph and integrating the velocity functions.
  • Understanding of basic kinematics and velocity components
  • Familiarity with integration and area under curves
  • Knowledge of trigonometric functions for angle calculations
  • Ability to interpret velocity-time graphs
  • Study the concept of displacement versus distance in kinematics
  • Learn how to calculate area under a curve for velocity-time graphs
  • Explore the use of integrals in physics for motion analysis
  • Review trigonometric identities and their applications in physics
Students studying physics, particularly those focusing on kinematics and motion analysis, as well as educators seeking to clarify concepts related to velocity and displacement.
barthayn
A rocket-powered hockey puck moves on a horizontal frictionless table. Figure EX4.8 at the top of the next column shows graphs of vx and vy, the x- and y-components of the puck's velocity. The puck starts at the origin.
a. In which direction is the puck moving at t = 2s? Give your answer as an angle from the x-axis.
b. How far from the origin is the puck at t = 5s?
The graph of the X-velocity is v=8t cm/s and the Y-velocity is V=30cm/s
c^2 = a^2 + b^2
d = vt
m= dy/dx
a. vx = 16 cm/s. vy = 30cm/s. θ = tan (30/16)^-1 = 62^o. Therefore the puck is traveling in the direction of 62^0 from the x-axis.
b. vx = 8* 5 = 40cm/s
dx = 40*5 = 200cm
dy= 30*5 = 150cm
c = (4000+2250)^0.5 = 250cm
Therefore, the puck is 250 cm from the origin.
My question are these:
For a I do not need to add the displacement of it, correct? Just the angle is good enough right? In high school there was never a question that did not involve the magnitude of the displacement.
Secondly. Is the position traveled from the origin correct as well? I am asking this because I am a bit confused because the position function for x-direction is 4x^2. It shouldn't matter if it is linear or not correct. I can still do it the way I solved it correct? As well for b, I do not need to include the angle because it is asking for the magnitude of the displacement, correct?
Your (a) looks correct.
dx = 40*5 = 200cm
200 cm is the distance it would have covered were it traveling at a constant speed of 40cm/s since the start. It has been traveling at less than this all the while, so your answer cannot be correct.
You need to find the displacement (from the origin) at time t=5 secs. The magnitude of this gives you the distance from the origin at t=5. Displacement is found as the area under the v-t graph. You have the graph, so you can work out the area under it.
Area has units. What units will the area under your v-t graph have?
Thanks, I forgot to half the area found because it was a triangle. To prove me correct I took the integral. I got 100 cm from x. So the final answer is 180.27cm from the origin, correct?
My answer is 180.27cm also.
