Optimizing Number Isolation: Equal vs. Unequal Bisection Strategies
  • Thread starter Thread starter Loren Booda
    Isolation
Loren Booda
Given a large but finite number line including an arbitrarily chosen number, what strategy of (un)equal bisections will isolate that number within a minimum of steps? For instance, should one choose equal bisecting, or would a series of unequal 2:1 bisecting be more efficient? Might e or phi be involved?
What do you mean by isolate?
Binary search is the fastest if you split into halves don't care about the results.
There's a puzzle (with, I'm told, applications in networking) where you've got two (or some number of eggs) and 100 (or some number) of floors, and you want to find out what the highest you can drop the egg from without breaking it as quickly as possible. Since only a small number of negative results is acceptable more exotic search strategies are preferred.
Dragonfall,
By isolate I mean eventually creating a section within which only a given number resides.
If you have a probability distribution, then you'll want to bisect the probability, and not the range.
For example, if the probability that the number is n is \frac{1}{2^n}, then you'd be splitting between 1 and 2, then 2 and 3, then 3 and 4, and so on.
I believe you're quite right, Nate.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
