Issue finding change in voltage across a resistor
The discussion revolves around calculating the voltage drop across resistor R1 in a circuit with resistors R1, R2, and R3. The user initially calculates the total current as 0.015A using the equivalent resistance of 816Ω and a supply voltage of 12V. However, the voltage drop calculated across R1 is incorrect, as the assumption that all current flows through R1 is flawed. It is suggested that the user should draw the circuit with labeled voltages and currents for clarity. Understanding the current distribution in the circuit is essential for accurate voltage drop calculations.
Blakeasd
Determine the voltage drop across R1
R1 = 770 , R2 = 630 , and R3 = 470 .
The equivalent resistance is 816Ω
V = IR
1.) I find the total current of the circuit:
V = IR -> I = V/R
I = 12v/816Ω = 0.015A
2.) I then find the voltage drop across that particular resistor:
V = IR
V = 0.015A * 770Ω
V = 11.32v
This has been confirmed to be the wrong answer.
I don't understand what I am doing incorrectly.
Could someone please help me understand my mistake (where ever it may be)?
Many Thanks!
You need to draw the circuit with all of the voltages and currents labeled so that you can see clearly what is going on. Thinking that the 15ma all goes through R1 is incorrect.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
