Calculating Angle Between Plumb Line & Radius Vector Over North Pole
The discussion revolves around calculating the angle between a plumb line in a jet plane flying due south over the North Pole and the radius vector from the Earth's center to the plane. Participants express confusion about the definition of the radius vector and the assumption that the Earth's angular velocity of 2π radians in 24 hours is merely an approximation rather than an exact value. Clarification is provided that this approximation relates to the difference between sidereal and solar days. The problem involves understanding the plane's path relative to the Earth's rotation and suggests that finding three points along the path could help determine the curve. Overall, the discussion emphasizes the complexities of the geometry involved in this scenario.
thesaruman
A jet plane flies due south over the north pole with a constant speed of 500 mph. Determine the angle between a plumb line hanging freely in the plane and the radius vector from the center of the Earth to the plane above the north pole.
Hint, assume that the Earth's angular velocity is 2pi radians in 24 hr, which is a good approximation. Why?
Well, I just can't figure out what radius vector is this... I mean, which plane is this? And I didn't understand why the hypothesis of an Earth's angular velocity of 2pi radians in 24hr is an approximation. I thought that this could be considered an exact parameter.
dx = v dt is one and v = \omega v dt \sin ( \theta ) is the other.
Considering that this plan is EXACTLY above the North pole, and that in the initial instant of time the jet plane is flying through this radius vector, the answer would depend of a time interval. What I could do?
I mean, the plane would be a distance dx = v dt \hat{\mathbf{x}} in \hat{\mathbf{x}} direction and simultaneously, the Earth would have turned an angle equal to \frac{d\omega}{dt} in \hat{\mathbf{\phi}} direction. I just can't eliminate the time from the solution.
First, just cleaning up the LaTex stuff so it displays properly:
... the plane would be a distance
dx = v dt \hat{\mathbf{x}} \ \mbox{in} \ \hat{\mathbf{x}} \ \mbox{direction}
\frac{d\omega}{dt} \ \mbox{in} \ \hat{\mathbf{\phi}} \ \mbox{direction.}
It looks like they want you to find the curve in the plane's path, which is straight line only relative to the rotating Earth. I'm not sure off the top of my head how to do that, but if you can find 3 points along the path it should be possible to fit a circle to them.
It has to do with a sidereal vs. solar day.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
