Convert Joules to Calories - 1 cal = 4.184 J
  • Thread starter Thread starter olop4444
    Calories Joules
1 calorie is defined as the energy required to raise the temperature of 1 gram of water by 1 degree Celsius, equating to 4.184 joules. The discussion highlights a misunderstanding in calculating this conversion using equipartition, where the calculated energy was incorrectly determined to be 1.38 joules. The discrepancy arises from the unique properties of water, particularly its hydrogen bonds, which contribute to a higher heat capacity than expected. As water's temperature increases, additional energy is required to break these bonds, leading to the established conversion factor. Understanding these molecular interactions is essential for accurate thermodynamic calculations.
olop4444
1 calorie is the energy needed to raise the temperature of 1 gram of water by 1 degree Celcius, i.e., the specific heat of water is 1 calorie/g-°C. How many joules is 1 calorie?
ΔU = nαkΔT
I attempted to use equipartition to solve this problem.
α of water should be 6*1/2 = 3.
1 gram of water should have 6.02*10^23 * 1/18 = 3.34 * 10^22 molecules
So to increase the temperature of 1 gram of water by 1° C or K, I obtained 3.34*10^22*3*1.38*10^-23*1 = 1.38 J.
However, it is well established that 4.184 J = 1 calorie. What am I doing wrong?
ΔU = nαkΔT
Welcome to PF!
Water behaves peculiarly when heated. It is because of its hydrogen bonds. The molecules not only vibrate around their equilibrium positions, but the hydrogen bonds also perform different coupled vibrations. These vibrations are excited more and more between zero and 100 °C. Water has much more degrees of freedom as 6 per molecule. The bonds can also break at higher temperatures, and that also consumes energy. All these result in heat capacity considerably larger than expected.
ehild
Interesting. I guess I'll learn more about that later in the course. Thanks for your help!
