Journal/References for MHD Propulsion
  • Thread starter Thread starter tictac
    Mhd Propulsion
MHD propulsion, or magnetohydrodynamic propulsion, is a topic of interest for both seawater and space applications, particularly involving magnetoplasmadynamic systems. Access to technical articles on this subject typically requires purchase, and there is a lack of readily available e-books specifically focused on MHD propulsion. A suggested starting point for research is the Wikipedia page on magnetohydrodynamics. The discussion highlights the novelty of MHD propulsion to some participants. Overall, finding free resources on this topic remains a challenge.
tictac
hi
i would like some journals/references on "MHD Propulsion"
please try to get it in ebook format...if not possible nytin else will do
but please avoid asking me to buy it.
thanx
Here is a starting place, which is free - http://en.wikipedia.org/wiki/Magnetohydrodynamics
Is one interested in propulsion in seawater or space, the later involving more or less magnetoplasmadynamic (MPD) systems.
Most technical articles in journals must be purchased. I don't know of any e-books on MHD propulsion.
I'd never actually heard of that before. Very cool.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
