Kinematic equation problems(HELP ME)
  • Thread starter Thread starter aprilgraceamo
    Kinematic
aprilgraceamo
An arresting device on a carrier deck stops an airplane in 1.5s. The average acceleration was 49 m/s^2. What was the stopping distance? What was the initial speed?
3. The Attempt at a Solution [/b
DONE! :D
No need for help anymore :D
Do you know your kinematic equations? Typically I try to actually reason out Physics problems (really understand why something is negative or positive or increasing etc) as this truly helps you to learn the material. However, if you are stuck on a question which actually counts toward your grade then the best way that I've found was to write all known data (not all that data will be explicitly stated, half of classical mechanics is being able to get that one key piece of information based on the data given to you) then write out all equations, plug everything in, see what you can solve for, rearrange equations etc. Basically just solve for everything mathematically and sooner or later you will get the variable they are looking for.
So just to give you a place to start. It sounds like a 1D motion problem (I'm picturing the airplane already on the carrier when it hits the stopping mechanism), so its going to be pretty basic.
What information do you know from the problem?
t(time) = 1.5s as an example.
What other info can you glean from the problem statement? Don't forget about setting up your reference frame so your signs will work out properly (this is a deceleration problem so some things will be negative and others will be zero).
This problem can be done with these two equations:
Vf=Vi + at
Xf=Xi + Vi*t + 1/2at^2
Once again look at the problem, see what data you have (both explicitly stated and implied under the circumstances), make sure your reference frame is set up properly to 1-make some of the math easier and 2-to make sure your signs are consisten. And go ahead and post up your attempt.
I'm already done with this one. Got an answer for it already. I was just confused about the signs and the what equation to use. But done already. Thanks for the info :D
Please give me some :(((
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
