How Long Does It Take for Two Cars to Meet in a Kinematic Problem?
  • Thread starter Thread starter rachael123456
    Car Kinematic
Car A starts from rest with an acceleration of 4.5 m/s², while Car B moves at a constant velocity of 25 m/s, initially 75 meters ahead. To determine when Car B catches up to Car A, kinematic equations are established for both cars. The velocity-time graph approach illustrates that Car B's position can be visualized as starting 3 seconds earlier than Car A, allowing for a clearer comparison of their distances over time. The areas under the graphs represent the distances covered, and when these areas are equal, Car A catches up to Car B, which occurs after 14 seconds of actual travel time for Car A.
rachael123456
Car a: starts moving from rest, acceleration= 4.5m/s², starting distance = 0m
car b : constant velocity of 25m/s, starting distance = 75m
How long will it take car b to catch up with car a?
Write kinematic equations for car a and car b separately.
For car a:d=0.5*a*(t^2)
For car b:s=v*t+starting distance.
equate d and s.Get t
Here a=4.5(acceleration) v=25(velocity) t is time in seconds.
You can "see" the answer if you draw velocity time graphs of the two cars.
SInce Car b is 75 m in front, when you start looking at them, you might imagine that it started 3 seconds earlier than the Car a.
[25 m/s for 3 seconds will give you 75 m]
The v-t graph for car b will be a horizontal line at v = 25
The v-t graph for Car a will be a sloping line starting at t=3 [seconds start for (b) remember]
The gradient of the line will be 4.5.
Once you have both lines, you will see two areas.
Firstly below Car b, above Car a - a trapezium. That area represents how far in front Car b will be by the time Car a is also traveling at 25m/s
Secondly a triangular area above Car b / below Car a [it becomes a triangle when you draw a vertical line at time t].
This triangular area represents the extra distance covered by Car a as it catches up.
When those two areas are equal, Car a has caught Car b.
Note that I started this example 3 seconds before the problem, so if it works out t = 17 seconds, Car a actually catches up after 14 seconds. [I made up the value 17 - hope I didn't guess the right answer]
The equations suggested by Bhaskar are excellent too.
