Kinematics of pumpkin shot out of air cannon
A 5kg pumpkin is launched from an air cannon at a 45-degree angle with an initial velocity of 54 m/s, landing 142 m away. The discussion focuses on calculating the air resistance force, modeled as F = -kmv, and integrating to find the velocity over time. The user initially struggles with incorporating the angle into their equations but eventually realizes the need to separate variables for time and account for both x and y components of motion. They successfully apply the perturbation method to determine the value of k, concluding with a result of 0.257 s^-1. The user expresses appreciation for the forum's knowledgeable community and aims to contribute positively.
tb.MSU
A pumpkin of mass 5kg is shot out of an air cannon at an elevation angle of 45 degrees with an initial velocity of 54m/s. It lands 142 m away. Assuming the force due to air resistance was F=-kmv, find the value of k.
I need some help with this problem. I'm not quite sure how to put in the angle. All i really know is:
F = ma = m(dv/dt) = -kmv ... after integration
ln v = -kt + C1 v(t=0)=Vo C1 = ln Vo
thus:
v = Vo(e^-kt)
i know this is completely off though because no where is there a sin or cos for me to input the angle..
any help would be much appreciated thanks!
ps. I'm a second year student at Michigan State. Astrophysics major.. gone through Calc 4.
tb
U forgot about the gravity force and the fact that the 2-nd law of Newton is a vector equation.
Daniel.
i'm actually starting to get somewhere now...
x(t=0) = 0 = y(t=0)
x(t=0) = Vo cos theta
y(t=0) = Vo sin theta
mx = -kmx
my = -kmy - mg
and I'm basically solving from there... i think i'll be okay on this question now, but any pushes while I'm on the swing will be w00teriffic. :)
Okay,post any "accidents" along the way. :-p
Daniel.
okay figured it out
i ended up having to set separate variables for time and also had to find the projectile range with and without air resistance.
this put me in an expansion parameter or coupling constant. For short, i used the "perturbation method" to come to a final answer of .257s^-1
R` = R (1 - ((4kVo sin theta)/3g))
where R = (Vo^2/g)sin 2 theta
Anyway,
I just found this page surprisingly. I was reading through a lot of other posts and noticed that there are several intelligent people posting and commenting on this site, so i figured i'd try and join up in hopes to better myself and others is possible.
Cheers,
tb
(GO STATE!)
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
