Kinetic energy of 2 cart system
The discussion focuses on calculating the translational kinetic energy (KE) of a two-cart system before collision, specifically a 371 kg cart moving at 1.90 m/s and a 495 kg cart moving at 2.09 m/s. The formula used for kinetic energy is K = 1/2 mv². The total translational kinetic energy is the sum of the individual kinetic energies of both carts. It is emphasized that during a collision, not all kinetic energy may be converted into other energy forms due to the conservation of momentum.
  • Understanding of kinetic energy calculation using K = 1/2 mv²
  • Knowledge of conservation of momentum principles
  • Familiarity with concepts of translational and convertible kinetic energy
  • Basic physics of collisions, including perfectly inelastic collisions
  • Calculate the total kinetic energy of the two-cart system using the provided masses and velocities
  • Explore the differences between translational kinetic energy and convertible kinetic energy
  • Study the principles of conservation of momentum in collision scenarios
  • Investigate the effects of inelastic collisions on energy transformation
Physics students, educators, and anyone interested in understanding kinetic energy calculations and collision dynamics in mechanics.
Axel7
On cart with a mass of 371 kg and another cart with a mass of 495 kg are rolling toward each other. Just before they collide, the 495 kg cart has a speed of 2.09 m/s, and the 371 kg cart has a speed of 1.90 m/s. We will consider the friction between the cart wheels and track negligible for this problem. Evaluate the translational kinetic energy and convertible kinetic energy of the two-cart system before they collide.
K=1/2mv^2
Do you find the kinetic energy for both of the carts? or average the speeds? Also what's the different between translational kinetic energy and convertible kinetic energy
The total translational KE of a system is the sum of the KE's of all its moving parts.
Now consider a scenario in which there is a two-body collision. Even if the collision is perfectly inelastic it is not always possible to convert all the KE into some other form of energy (like heat or sound or potential energy). This is because conservation of momentum will dictate what the final velocity of the combined object will be post-collision. If there's motion remaining then there's KE remaining, too. So that portion of the original KE could not be converted.
Thank you so much! This helps a lot!
  • · Replies 32 ·
  • · Replies 40 ·
  • · Replies 24 ·
