Kinetic energy- pushing an object up an incline.
7 replies · 4K views
bopll
An object is given an initial velocity of 3.0 m/s up a 20 degree incline. Mass= 22.3 kg and coefficient of kinetic friction is .93.
W = (1/2)mv1^2-1/2mv0^2
W = Fdcos(u)
So I added the forces together, mgsin(20) + .93mgcos(20)
and this times cos(20) should be the total work, right?
so then since the change in kinetic energy equals work i set -(1/2)mv^2= -Fdcos(20)
plugging in the mass for m, initial velocity for v, the forces due to friction and gravity for F, and solving for d, i got the wrong answer. where'd i go wrong? I also tried this taking out the cos(20) in the second work equation and still got it wrong.Thanks, this is my first time using physics forums and i really hope i can get to understand this stuff...
Well I say you've done it fine by adding up the two forces.
What I would have done then would be to tilt the axes 20 degrees such that it's parallel with the incline. We'll call this axis the x.
We know that the magnitude of net force acting on the x-axis is mgsin(20) + 0.93cos(20).
Therefore just use [tex]\frac{1}{2}mv^2 = F\Delta d[/tex]
that's what i did :-\
it came out to .3979 ish and that wasn't right...
