How Does Kinetic Energy Change at Maximum Height in Projectile Motion?
In summary, this conversation discusses a question about an object being thrown upwards with a kinetic energy of E. When the object reaches its maximum height, its kinetic energy only comes from the horizontal component of its velocity, which is equal to half of its initial velocity. Therefore, the final kinetic energy at the top of the motion is 0.25E. This concept of separable kinetic energy in different spatial directions is significant in understanding why kinetic energy is proportional to velocity squared.
Brianne
kinetic energy stuff...
here's the question...
an object is thrown upwards at a projection angle of 60 degree with kinetic energy E. When the object reaches max height, its kinetic energy becomes
A. (1/8)E
B. (1/4)E
C. (1/2)E
D. (3/2)E
I'm totally no idea...some1 kindly tells me the concept of this question... x_x
When the object is just launched it has E Cos (60) energy in the horizontal direction and E Sine (60) in the vertical direction. When it arrives at the top end of travel (vertically) it only has the horizontal energy left.
Therefore it is E Cos (60) = 0.5 E
You need to know what percentage of the object's initial KE is associated with the horizontal component of its velocity. (The part associated with the vertical component will go to zero at max height.) Hint: If the initial speed is V, what's the horizontal component of the velocity?
i've seen the answer is 0.25E from the book, so I just think should we squaring the cos60, ie (cos60)^2=0.25?
Doc Al: if the horizontal component of velocity remains unchange in a projectile motion, so the velocity is still v isn't it?
Initial Kinetic energy : E = [itex]\frac{1}{2}mv^2[/itex]
K.E at the highest position: [itex]\frac{1}{2}m(v cos60)^2[/itex]
Rest i leave upto you.
BJ
Brilliant question, makes you see _why_ KE _is_ proportional to velocity squared. If you think about KE has to be, then, this question reveals that it must be proportional to velocity squared simply because it is separable in the different spatial directions. WOW it really blows my mind. It is probably neater to say that the velocity in the horizontal direction is half the initial straight line velocity from simple geometry rather than having to appeal to trig (though trig is more general). And then say it this half velocity that you are squaring to get the quarter energy.
Yes, but why? The answer is to compare the initial KE (which comes from both the vertical and horizontal components of the initial velocity) to the final KE (which comes only from the horizontal speed). (See Dr.Brain's post.)
I'm not sure what you mean. If the initial velocity (with magnitude V) has components:
[itex]V_{ix} = V \cos \theta[/itex]
[itex]V_{iy} = V \sin \theta[/itex]
Then at the top of the motion, since the vertical component is zero, the velocity will have components:
[itex]V_{fx} = V \cos \theta[/itex]
[itex]V_{fy} = 0[/itex]
FAQ: How Does Kinetic Energy Change at Maximum Height in Projectile Motion?
1. What is kinetic energy?
Kinetic energy is the energy an object possesses due to its motion. It is a form of energy that is transferred from one object to another when work is done.
2. How is kinetic energy calculated?
The formula for calculating kinetic energy is KE = 1/2 * m * v^2, where m is the mass of the object and v is its velocity.
3. What are some examples of kinetic energy?
Some examples of kinetic energy include a moving car, a rolling ball, a swinging pendulum, and a flying airplane. Basically, any object that is in motion has kinetic energy.
4. How is kinetic energy different from potential energy?
Kinetic energy is the energy an object has due to its motion, while potential energy is the energy an object has due to its position or state. Kinetic energy can be converted into potential energy, and vice versa.
5. How is kinetic energy important in everyday life?
Kinetic energy plays a crucial role in our daily lives. It is what allows cars to move, planes to fly, and our bodies to perform physical activities. It is also used in many forms of energy production, such as hydroelectricity and wind turbines.
