Calculating Friction Coefficient with 40 N Force and 5 kg Box
To calculate the coefficient of friction for a 5 kg box being pushed with a force of 40 N and accelerating at 0.70 m/s², it's essential to determine the net force acting on the box. The net force can be calculated using Newton's second law, which states that force equals mass times acceleration. If the applied force differs from the net force, it indicates the presence of friction, which is the force opposing the motion. The discussion emphasizes that understanding the net force is crucial for finding the coefficient of friction, rather than focusing on kinetic energy. Properly addressing these calculations will lead to the correct determination of the friction coefficient.
kirstynl
okay, i tried searching knietic energy and it won't come up,
soooo here's a questions:
a force of 40 N continues to push a 5 kg box and acclerates it a .70 m/s/s what is the coefficient of friction/
i got the static because it wasn't movingm, but i have no idiea how to get that please help
First, tell us what was the net force acting on the body.
This problem has nothing to do with kinetic energy! As shooting star said (I seem to spending the day right behind him!), it is entirely a matter of force. What is the net force on the body? Also I have no idea what you mean by "I got the static because it wasn't moving". What wasn't moving? What "static"?
Do you by chance mean you "get" the case for static friction? Anyway, reply to our questions if you want to understand the problem.
if the acceleration is .7 m/s^2, and the box has a mass of five kilograms, Newton will only take a second to tell you the net force on the box.
Of course, if there's a difference between the applied force and the net force, there must be another force acting on the box. This is where you'll find your kinetic friction.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
