Calculating Total Kinetic Energy After Explosion
To calculate the total kinetic energy after the explosion, both vertical and horizontal components of velocity must be considered. The vertical velocity (Vy) was calculated as 11.96 m/s using the equation for free fall. The horizontal distance of 11.2 m requires determining the time of flight to find the horizontal velocity (Vx). The total velocity is the vector sum of Vy and Vx, which is essential for calculating total kinetic energy using the formula KE = 1/2(mv^2). Therefore, both components must be included to accurately find the total kinetic energy of the system.
Grogerian
Find the total kinetic energy in the system. a explosion fires two pieces both 7.3m high and 11.2m horizontally total kinetic energy done by the explosion the first piece is 15kg, the second 26kg?
kinematics
Ke=1/2(mv2)
I found that Vi(y) = \sqrt{2(9.81)(-7.3)} = 11.96 m/s do i just use this to find the total energy done? or do i need to consider the x-dir as well, If so how do i do that?
Hi Grogerian!
The KE depends on the total speed, as you know, so Vy is obviously not enough unless Vx is zero.
(but I can't help any furher, as I don't understand the question. :redface:)
kinematics
Ke=1/2(mv2)
Velocity is the sum of the components, so yes, you do need to determine the x component.
Since you can figure the time to drop 7.3m from the peak and you know that will be half the time of its flight, and you know that is 7.3m = 1/2 g*t2. Now you can figure how fast it was to go 11.3m.
