Kinetic Energy: Calculating with a Bowling Ball
Naldo6
A bowling ball of mass 8.04 kg and radius 8.48 cm rolls without slipping down a lane at 5.22 m/s. Calculate its total kinetic energy.
What is the formula for Kinetic energy (hint)
