Kinetic Friction of Blocks: Mass M & 2M, 0.500m/s^2
  • Thread starter Thread starter JUniTo24
    Home Work
The problem involves three blocks, with block 1 having mass M and block 2 having mass 2M, accelerating at 0.500 m/s² after being released from rest. To find the coefficient of kinetic friction between block 2 and the table, it is essential to analyze the forces acting on each block and apply Newton's second law. By setting up equations for each mass, one can derive a system of equations that can be solved simultaneously to determine the value of the coefficient of kinetic friction (μ). A diagram is suggested to visualize the forces involved, aiding in the analysis. The discussion emphasizes the importance of clearly stating the problem and showing the work involved in reaching the solution.
JUniTo24
When the three blocks are released from rest, they accelerate with a magnitude of 0.500m/s^2.Block 1 has mass M, block 2 has 2M.What is the coefficient of kinetic friction between block 2 and the table?
Please provide a complete statement of the problem (include a diagram, if possible), show your work, and point out where you are stuck.
Diagram of problem
http://i260.photobucket.com/albums/ii15/Jose243_photo/diagrama.jpg"
Take each mass in turn, analyze the forces on it, and apply Newton's 2nd law. You'll get three equations that you can solve together to find μ.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
