Solve Kinetic Friction Homework: Acceleration & Time Before Rock Goes Over Edge
In summary, a 75 kg climber is roped to a 980 kg rock located 51 m from the edge of an ice cliff with a coefficient of kinetic friction of 5.5×10−2. The climber's acceleration is -2.76 m/s^2 and he has limited time before the rock goes over the edge. The equation for the rock is \sum F = ma and the tension of the ropes should not be equated to the friction force.
orange03
A 75 kg climber finds himself dangling over the edge of an ice cliff, as shown in the figure below. Fortunately, he's roped to a 980 kg rock located 51 m from the edge of the cliff. Assume that the coefficient of kinetic friction between rock and ice is 5.5×10−2. What is his acceleration, and how much time does he have before the rock goes over the edge? Neglect the rope's mass. What is his acceleration? How much time does he have before the rock goes over the edge?
F=ma
equation of the climber:
Ft-mg=may
equation of the rock:
Ft=Fr
I found the tension of the ropes by this equation: Ft=ukN=(.055)(980)(9.8) = 528.22N. I plugged this back into the climber's equation and got -2.76 m/s^2 but this answer is wrong. Help please!
Ft=Fr
The equation of the rock is wrong
The tension is not the same as friction because the rock moves with acceleration.
Use [tex]\sum F[/tex] = ma to get the equation for the rock
I would first like to commend you on your attempt at solving this problem. However, there are a few mistakes in your equations and approach that may have led to the incorrect answer. Let's break down the problem and see where we can make corrections.
First, let's define the forces acting on the climber and the rock. For the climber, we have the tension force from the rope pulling up, the weight force (mg) pulling down, and the friction force (Ff) acting in the opposite direction of motion. For the rock, we have the tension force pulling up and the weight force pulling down.
Now, let's set up the equations of motion for the climber and the rock. For the climber, we have:
ΣF = Ft - mg - Ff = may
For the rock, we have:
ΣF = Ft - mg = mar
We can see that the tension force (Ft) is present in both equations. This is because the climber and the rock are connected by the rope, so the tension force is the same for both of them. Now, let's find the values of the other forces.
The weight force for both the climber and the rock is simply their respective masses (m) multiplied by the acceleration due to gravity (g = 9.8 m/s^2).
The friction force is given by the equation Ff = μkN, where μk is the coefficient of kinetic friction and N is the normal force. The normal force in this case is equal to the weight force (mg) for both the climber and the rock.
Plugging in the values, we get:
For the climber: Ft - (75 kg)(9.8 m/s^2) - (0.055)(75 kg)(9.8 m/s^2) = (75 kg)a
For the rock: Ft - (980 kg)(9.8 m/s^2) = (980 kg)a
We can solve these equations simultaneously to find the value of the tension force (Ft) and the acceleration (a).
Next, we need to find the time before the rock goes over the edge. We can use the equation d = vot + 0.5at^2, where d is the distance (51 m), vo is the initial velocity (which we can assume is 0 m/s since the rock is initially at rest), a
Related to Solve Kinetic Friction Homework: Acceleration & Time Before Rock Goes Over Edge
What is kinetic friction?
Kinetic friction is the force that opposes the motion of an object when it is in contact with a surface. It is caused by the microscopic irregularities of the two surfaces rubbing against each other.
How does kinetic friction affect acceleration?
Kinetic friction acts in the opposite direction of the motion, so it can decrease the overall acceleration of an object. This means that the object will take longer to reach its final velocity and will also take longer to complete its motion.
What factors can affect the amount of kinetic friction?
The amount of kinetic friction depends on the nature of the two surfaces in contact, the force pressing the two surfaces together, and the roughness or smoothness of the surfaces. The presence of lubricants or other substances can also affect the amount of kinetic friction.
How can we calculate the time before a rock goes over the edge?
To calculate the time before a rock goes over the edge, we first need to determine the acceleration of the rock due to gravity. Then, we can use the equation t = √(2h/g), where t is the time, h is the height of the edge, and g is the acceleration due to gravity. This will give us the time it takes for the rock to reach the edge.
What are some real-life applications of understanding kinetic friction?
Understanding kinetic friction is important in many real-life situations. For example, it is essential in designing vehicles with proper braking systems, creating efficient machinery, and even in sports like ice skating and skiing where minimizing friction is crucial for performance. It also helps us understand and predict the behavior of objects in various situations, such as the time it takes for a rock to roll down a hill or the distance a car will skid before coming to a stop.
9K
9K
