Lagrange Multipliers to find the Maximum and Minimum values
brendan
Use Lagrange Multipliers to find the Maximum and Minimum values of f(x,y) = x2-y.
Subject to the restraint g(x,y) = x2+y2=25
gradient f(x,y)= gradient g(x,y)
I have found the gradients of f and g to be
f(x,y) = 2xi + -1j
g(x,y) = 2xi + 2yj
I have put these to gether with the constraint to find the simutaneous equation
2x = lambda 2x
-1 = lambda 2y
x2+y2 = 25
Have I got this system right so far ?
I'm a bit concerned about the 2x = lambda 2x part.
I'm not sure if this is right or I should have used 2x = lambda 2y ?
In the original system I have Lambda = 1 and y = -1/2
Any help greatly appreciated
Brendan
I'm not sure if this is right or I should have used 2x = lambda 2y?
Everything looks right to me, and no, you definitely should not have used 2x=\lambda 2y. The general system for a function f(x,y) constrained to g(x,y) = k is:
\begin{align*}<br /> f_x &amp;= \lambda g_x \\<br /> f_y &amp;= \lambda g_y \\<br /> g &amp;= k<br /> \end{align*}
So you have done this exactly right. You have found \lambda=1,y=-1/2 correctly. What about x?
What are you concerned about? I think you are doing fine. 2x = lambda 2y isn't right at all. Why would you think it is?
g(x,y) = x2+y2=25
Now we have y = -1/2
so x = sqrt(y2+25) or -sqrt(y2+25)
= sqrt(101)/2 or -sqrt(101)
So we have two solutions
f(x,y)= x2-y = f(sqrt(101)/2,-1/2) = 103/4 = 25.75
f(x,y)= x2-y = f(-sqrt(101)/2,-1/2) = 103/4 = 25.75
So they are both the maximum
brendan said:
g(x,y) = x2+y2=25
Whoops, you have a sign error. It should have been x = \pm\sqrt{25-y^2}.
g(x,y) = x2+y2=25
so x = sqrt(25-y2) or -sqrt(25-y2)
= sqrt(99/4) or -sqrt(99/4)
f(x,y)= x2-y = fsqrt(25-y2) ,-1/2) = 101/4= 25.25 (maximum)
f(x,y)= x2-y = f(-sqrt(25-y2) ,-1/2) = -97/4= -24.25 (Minimum)
Is that better?
