Lagrangian mechanics of continuous systems
This discussion focuses on the generalization of Lagrangian mechanics to continuous systems with infinitely many degrees of freedom, specifically conservative systems that do not explicitly depend on time. The author presents a modified Lagrangian, defined as an integral over a continuous parameter, and derives the corresponding Euler-Lagrange equations. The example provided involves a continuous spring, leading to a motion equation that describes oscillatory behavior. The conversation highlights the connection to Lagrangian field theory and emphasizes the importance of Lagrangian density in this context.
  • Understanding of Lagrangian mechanics and its equations of motion.
  • Familiarity with calculus of variations and functional derivatives.
  • Knowledge of classical field theory and Lagrangian density concepts.
  • Basic principles of mechanics involving continuous systems and oscillations.
  • Study the derivation of Euler-Lagrange equations for Lagrangian densities.
  • Explore classical field theory literature to understand applications of Lagrangian mechanics in continuous systems.
  • Investigate the implications of infinitely many degrees of freedom in physical systems.
  • Learn about the mathematical techniques used in calculus of variations relevant to Lagrangian mechanics.
Physicists, mechanical engineers, and researchers in theoretical mechanics who are interested in advanced applications of Lagrangian mechanics and continuous systems.
adriank
I'm thinking about generalizations of Lagrangian mechanics to systems with infinitely many degrees of freedom, but what I've got uses some extremely sketchy math that still appears to give a correct result. I only consider conservative systems that do not explicitly depend on time.
Of course, if our system is described by finitely many coordinates [itex]q_i[/itex] and a Lagrangian [itex]L = L(\mathbf{q}, \dot{\mathbf{q}})[/itex], then the motion obeys Lagrange's equation
[tex]\frac{\partial L}{\partial q_i} - \frac{d}{dt} \frac{\partial L}{\partial \dot q_i} = 0,[/tex]
or equivalently,
[tex]\frac{\partial L}{\partial \mathbf{q}} - \frac{d}{dt} \frac{\partial L}{\partial \dot{\mathbf{q}}} = 0,[/tex]
where [itex]\partial L / \partial \mathbf{q}[/itex] is a directional derivative
[tex]\frac{\partial L}{\partial \mathbf{q}}(\mathbf{v}) = \left. \frac{d}{d\tau} L(\mathbf{q} + \tau \vect{v}, \dot{\mathbf{q}}) \right\rvert_{\tau = 0},[/tex]
and similarly for [itex]\partial L / \partial \dot{\mathbf{q}}[/itex].
Now say our system is described by some continuous parameter [itex]s[/itex], so we again have [itex]L = L(q, \dot q)[/itex], but this time [itex]q[/itex] is a function of both [itex]s[/itex] and [itex]t[/itex]. I make the bold claim that Lagrange's equation still holds in this sense:
[tex]\frac{\partial L}{\partial q} - \frac{d}{dt} \frac{\partial L}{\partial \dot q} = 0,[/tex]
where the derivatives of the Lagrangian are some functional directional derivative:
[tex]\frac{\partial L}{\partial q}(f) = \left. \frac{d}{d\tau} L(q + \tau f, \dot q) \right\rvert_{\tau = 0},[/tex]
where [itex]f[/itex] is some function of [itex]s[/itex].
As an example, suppose we have a continuous spring, with an unextended length of 0, confined to the [itex]y[/itex] axis. Its position is described by a function [itex]y(s, t)[/itex], where [itex]s[/itex] ranges from [itex]0[/itex] to [itex]\ell[/itex]; the parameter [itex]s[/itex] perhaps represents length along the coil from one end. Its mass and spring constant per unit length are [itex]\mu[/itex] and [itex]\kappa[/itex]. I write [itex]y'[/itex] to mean [itex]\partial y / \partial s[/itex]. The potential energy and kinetic energy are
[tex]V = \int_0^\ell \mu g y(s) + \frac12 \kappa \left( \frac{\partial y(s)}{\partial s} \right)^2 \,ds, \quad<br /> T = \int_0^\ell \frac12 \mu \dot y(s)^2 \,ds,[/tex]
so the Lagrangian is
[tex]L = \int_0^\ell \frac12 \mu \dot y(s)^2 - \mu gy(s) - \frac12 \kappa y'(s)^2 \,ds.[/tex]
The directional derivatives with respect to [itex]y[/itex] and [itex]y'[/itex] of the Lagrangian satisfy
[tex]\frac{\partial L}{\partial y}(f) = \left. \frac{d}{d\tau} \int_0^\ell \frac12 \mu \dot y(s)^2 - \mu g (y(s) + \tau f(s)) - \frac12 \kappa (y'(s) + \tau f'(s))^2 \,ds \right\rvert_{\tau = 0} = -\int_0^\ell \mu g f(s) + \kappa y'(s) f'(s) \,ds[/tex]
[tex]\frac{\partial L}{\partial \dot y}(f) = \left. \frac{d}{d\tau} \int_0^\ell \frac12 \mu (\dot y(s) + \tau f(s))^2 - \mu gy(s) - \frac12 \kappa y'(s)^2 \right\rvert_{\tau = 0} = \int_0^\ell \mu \dot y(s) f(s) \,ds[/tex]
Thus, Lagrange's equation gives
[tex]\int_0^\ell \mu g f(s) + \kappa y'(s) f'(s) + \frac{d}{dt} \mu \dot y(s) f(s) \,ds = 0.[/tex]
Integration by parts on the second term and simplifying gives
[tex]\kappa (y'(\ell) f(\ell) - y'(0) f(0)) - \int_0^\ell \left[ \mu g - \kappa y''(s) + \mu \ddot y(s) \right] f(s) \,ds = 0.[/tex]
I claim that somehow the term on the left disappears. Since this equation must be true for any function [itex]f[/itex], the expression in brackets must be zero; we then get the equation of motion
[tex]\ddot y(s) = \frac{\kappa}{\mu} y''(s) - g.[/tex]
It seems like a physically reasonable equation; solutions oscillate over time, and if we say fix [itex]y(\ell) = 0[/itex], then in an equilibrium solution [itex]y(s) = (\mu g/2\kappa) (s^2 - \ell^2)[/itex] the tension [itex]\kappa y'(s)[/itex] at any point is equal to the weight [itex]\mu gs[/itex] of the spring below that point.
Has anyone seen anything that looks somewhat like this? I looked around and couldn't really find anything that looked like this.
cool, so you've reinvented Lagrangian field theory! Since your Lagrangian is an integral over s, is better to consider its integrand and call it a "Lagrangian density". Can you derive the Euler-Lagrange equations for a Lagrangian density? In any case, I hope you have enough buzzwords now to read up on this, there's a huge literature on classical field theory.
  • · Replies 59 ·
