Laplace Transform Diff EQ Help Request
keebler71
Ok...so this isn't homework (well past that at 39!) but I'm trying to brush off the old cobwebs and solve a vehicle motion problem. Specically, I'm trying to find the
Ok...so this isn't homework (well past that at 39!) but I'm trying to brush off the old cobwebs and solve a vehicle motion dynamics problem. Specifically I’m trying to solve for the velocity history of the vehicle subject to accelerations that vary with the velocity and velocity squared. Eventually I’ll add a forcing term and I’d like to solve this using the Laplace Transform.
Here is a generalized version of the equation:
v’ (t) = k1*v(t)^2 + k2^v(t) + k3
The left side is easy:
L[v’(t)] = sV(s) - v(0)
But I’ve been stumped by the right side. Specifically, I am having trouble finding the L[v(t)^2] term. I’ve tried substituting into the definition of the LT and integrating by parts but not luck so far and can't find an similar example on the web or in a table... Any suggestions?
I don't think the Laplace transform is appropriate for this problem because you don't have a linear differential equation due to the v2 term. The differential equation is separable, though.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
