Latent heat and phase change question
A 100g cube of ice at 0 degrees Celsius is dropped into 1.0kg of water at 80 degrees Celsius, prompting a discussion on calculating the final temperature after the ice melts. The key equations involve heat transfer, where the heat gained by the ice equals the heat lost by the water. Participants emphasize the importance of recognizing that the final temperature (Tf) will be the same for both the melted ice and the water. Clarifications are made regarding the initial temperatures and the phases involved during the melting process. The final temperature must be solved as an unknown, taking into account the latent heat of fusion and the specific heat capacities of both substances.
mizzy
A 100g cube of ice at 0 degrees is dropped into 1.0kg of water that was originally at 80 degrees. What is the final temperature of the water after the ice has melted?
Q = ml
Q = mc(Tf - Ti)
i'm not sure again about the temperature, but this is what i did:
1) Qice = mc (Tf - Ti) where, m = .100kg, c = 2090, Tf = NOT SURE, 80 degrees??, Ti=0
Q = ml where, m = .100kg, L = 3.33 x 10^5
Qicewater = mc (Tf - Ti) where, m = .100, c = 4186, Tf = NOT SURE, Ti = 0
Qwater = mc(Tf - Ti) where, m = 1.0, c = 4186, Tf = ?, Ti = ?
can someone help me please?
1st you need to find the latent heat of fusion of water
then water: Tf=? Ti=80
ice: Ti=0 Tf=Tfwater=??
then add up the energys
I know I'm suppose to add up the energies, but I'm not sure about my temperatures.
what's the final temperature of the ice? Initial temp is 0 degrees, but what's the final?? is it 80 degrees?
If the final temperature was 80 degrees, you'd already have your answer!
The trick is that all the water will end up at the same final temperature, which you have to solve for. That's your unknown.
Set up your heat flow equation and solve for Tf.
but if you look at my first posting...what's the initial temperatures for Qicewater and Qwater?
I always get stumped on temperatures and also on phase changes. FOr example, if a block of ice is put into water, the phases are: ice, ice water, water...right?
The initial temp for Qwater is given as 80 degrees. When the ice just melts, what is the temp of the water? (Does temperature change during a phase change?)
I'd just call it ice and water. (But the water changes temperature as it gains/loses heat energy.)
The mass of ice melts, then increases its temperature to the final temperature.
The mass of water loses heat and thus lowers its temperature to the final temperature.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
