Laurent Series Expansion of $\frac{1}{z^2-1}$
gtfitzpatrick
Calculate the laurent series expansion about he points specified, classify the singularity and sate the region of convergence for.
\frac{1}{z^2 - 1} at (i) z=1 (ii) z=-1 (iii)z=0
\frac{1}{z^2 - 1} = \frac{1}{2(z-1)} - \frac{1}{2(z+1)}
i observe that f(z) is analytic in {z≠ -1,1} so is anyalytic in -1 < \left|z\right| &lt; 1
@z=1 \frac{-1}{2}\frac{1}{1-(-z)} = \frac{-1}{2}\sum (-z)^n
similarly
@z=-1 \frac{1}{2}\frac{1}{(z-1)} = \frac{-1}{2}\frac{1}{1-z)} = \frac{-1}{2}\sum (z)^n
and
@z=0 is it just the sum of both of them? singularities are at 1, -1 and region of convergence -1 < \left|z\right| &lt; 1
am i anywhere near?
similarly
and
am i anywhere near?
No. When you expand around a point z0, then the series should be in powers of (z-z0). So for the first one, the first partial term is already in powers of z-1. However for the second term:
-1/2 \frac{1}{z+1}
that's not. But you can do so by forcing a factor of z-1 in the denominaor by:
\frac{1}{z+1}=\frac{1}{z-1+2}=\frac{1}{2+z-1}|=\frac{1}{2(1+\frac{z-1}{2})}
which you can then easily express that as a power series in terms of (z-1) right? Same dif with the other ones.
thanks a million jackmell
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
