Solving Fish Refraction Problem Using Law of Refraction
  • Thread starter Thread starter on204
    Law Refraction
The discussion centers on understanding how a fish perceives its surroundings through the lens of the law of refraction. Participants emphasize the importance of visualizing the scenario, considering how light bends when transitioning from air to water. The fish's ability to see someone on the shore depends on the angles of refraction and the observer's position relative to the water's surface. Engaging with the problem is encouraged, as initial attempts, even if incorrect, can lead to better insights. Ultimately, the exercise aims to deepen comprehension of refraction and its implications in real-world scenarios.
on204
Imagine a fish in the lake. And assume that the surface of the water is absolutely flat--no waves at all. Draw a picture and describe what the fish should see. Can the fish see someone standing on the shore of the lake?
I think that using the law of refraction I can solve this somehow, but I'm not really sure where to start. Could someone please help me out. Thank you.
What do YOU think? The forum rules say no one can help you until you start the problem. Even making a mistake would be helpful.
Think about it, what is a perfectly flat surface of water with no waves a metaphoric equivalent to?
