Let me try to get this straight.
  • Thread starter Thread starter kmarinas86
The discussion centers on the relationship between induced electromotive force (emf) in a coil and the velocity of a magnet, emphasizing that induced emf cannot exceed the initial emf used to spin the magnet. It explores the concept of using a transformer to adjust voltage, noting that while doubling voltage theoretically doubles electrical input power, transformers maintain constant power with trade-offs in current. The efficiency of the motor is limited by the back emf relative to the input voltage. A critical point raised is the kinetic energy of the rotor, which increases with the square of the rpm, suggesting a potential misunderstanding in the design's assumptions. The conversation highlights the need for clarity in the overall design to address these complexities.
kmarinas86
The emf induced in a coil by a magnet is proportional to the velocity of that magnet. The induced emf cannot exceed the emf used to cause the magnet to spin in the first place. Right? So let's say this initial emf source was current from that same loop in which the induced emf will result. Let's say we know the input current to be 1 amp and we allow to the voltage going into the coil to change. We could use a transformer to do this right? Obviously, if that is set to be the case, then doubling the voltage would double the electrical input power. The limit to the motor's efficiency is the back emf relative to the input voltage is it not? Since voltage is magnetic flux change per unit time (i.e. webers per second), shouldn't we expect the magnet to be able to spin faster in rpms proportional to the coil input voltage, assuming that friction was negligible? The problem with this view is that the kinetic energy of the rotor would increase with the square of the rpm, assuming that the magnet rotor has a constant moment of inertia. I am missing something, but what is it?
<The induced emf cannot exceed the emf used to cause the magnet to spin in the first place. Right? >
That is not generally true. Can you be more specific about your design?
<We could use a transformer to do this right? Obviously, if that is set to be the case, then doubling the voltage would double the electrical input power.>
In the ideal case, transformers maintain the same power. As voltage goes up, current goes down and vice-versa. In the real case, a small% of the power is lost to heat.
I don't really understand your overall design. What is this?
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
