Lift and Pressure Question ( )
  • Thread starter Thread starter physicsCU
    Lift Pressure
To determine the coefficient of lift (Cl) using the average coefficient of pressure (Cp) on the upper surface of a wing, it's essential to recognize that this surface contributes 3/4 of the total lift. The relationship between Cp and Cl can be established through the integration of Cp over the wing's surface. To solve the integrand for the Cl integral, one must integrate the Cp values across the relevant area of the wing, factoring in the freestream velocity (V). The final Cl can be calculated by applying the appropriate aerodynamic formulas to the integrated results. This approach will yield the coefficient of lift based on the given parameters.
physicsCU
I also posted this in the homework help, but I may get more help here.
This is the problem:
We are given either a local velocity or local coefficient of pressure. Using one, the other can be solved. Freestream V is given.
Now, if that Cp is the average Cp on the upper surface of a wing and that upper surface provides 3/4 of the lift, what is the coefficient of lift?
How would I solve the integrand of the cl integral?
respond to the homework help thread. Please do not doublepost.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
