Light attracted to earths gravity
  • Thread starter Thread starter theblindlead
    Gravity Light
Light is influenced by gravity, as described by general relativity, causing it to bend when near massive objects. In the scenario presented, a beam of light is directed horizontally between two mirrors positioned 7 m apart and 13 m above the ground. To find the time it takes for the light to hit the ground, calculations based on the distance and the speed of light are necessary. Additionally, the number of reflections, N, can be determined by analyzing the path of the light as it bounces between the mirrors before reaching the ground. Proper formatting and effort in problem-solving are required for homework submissions in the forum.
theblindlead
Falling light. According to general relativity and the equivalence principle, light is bent by gravity. Consider two tall, perfectly reflecting mirrors exactly 7 m apart and facing each other. A beam of light is directed horizontally through a hole in one of the mirrors 13 m above the ground.
(a) Determine the time it takes for the light to strike the ground.
b) The light will undergo N reflections (i.e., N/2 reflections from each mirror) before it strikes the ground. Find N.
Homework problems are to be posted using a specific format. Please read the forum rules. You have to show some effort on your part, you can't just ask for the answer.
