Limit and partial derivatives proof
cezarion
Prove that if all partial derivatives up to order n are zero at \vec{x} and f(x) = 0 then \displaystyle\lim_{h \rightarrow 0} \dfrac{f(x + h)}{|h|^n} = 0
\displaystyle\lim_{h \rightarrow 0} \dfrac{f(x + h) - f(x)}{|h|} = 0
f(x) = 0
I am not sure if I should be doing this by induction. The first case is trivial. For the general case I am unable to move beyond either the limit \displaystyle\lim_{h \rightarrow 0} \dfrac{0}{|h|^{k}}. I am also not sure how to formulate the equation for the k-th partial derivative. Is it permissible to use the same h for both a given derivative and the next derivative? Thanks for your help.
Are you certain that the first case it "trivial"? Knowing that the partial derivatives are tells you that \lim_{h\rightarrow 0}\frac{f(\vec{x}+ h\vec{e_i})- f(\vec{x})}{h} = \lim_{h\rightarrow 0}\frac{f(\vec{x}+h\vec{e_i})}{h}= 0 where h is a real number and \vec{e_i} is the unit vector in the ith coordinate direction. What you want to prove, \lim_{\vec{h}\rightarrow \vec{0}}\frac{f(\vec{x}+ \vec{h})}{|\vec{h}|^n}= 0 requires that h be a general vector going to the 0 vector. (It is, of course, very easy to prove one from the other. What is the derivative in direction \vec{h} in terms of the gradient or partial derivatives?)
Thank you for the reply. This was actually proved in our textbook, so I am just citing the result in the proof for this problem, leaving just the general case that needs to be proved.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
