Proof: Show that if det(A)=1, then adj(adj(A))=A
Mdhiggenz
Show that if the det(A)=1
then adj(adj(A))=A
Given Goal
det(A)=1 adj(adj(A))=A
Using the following formula A-1=adj(A)/det(A)
if det(A)=1 then A-1=adj(A)
likewise A=adj(A-1)/det(A-1)
if det(A)=1 then det(A-1)=1
Thus A=adj(A-1)
A=adj(A-1)=adj(A)adj=adj(adj(A))
What I'm confused about is
Not sure if this proof is correct, TA explained it rather quickly so I am running on pure memory.
I'm not sure about a few things
1.Why can we assume that det(A
2. why can we use the opposite relation to the equation A=adj(A-1)/det(A-1)
That's where I get a bit lost on the logic.
thanks
1) ??
2) You start off with ##\displaystyle A^{-1} = \frac{adj(A)}{det(A)}##
Let the matrix ##\displaystyle B = A^{-1}##. Plug B into the above formula and you have
##\displaystyle B^{-1} = \frac{adj(B)}{det(B)}##
##B## is just ##A^{-1}## so
##\displaystyle (A^{-1})^{-1} = \frac{adj(A^{-1})}{det(A^{-1})}##, and ##(A^{-1})^{-1}## is simply ##A##. Therefore, ##\displaystyle A = \frac{adj(A^{-1})}{det(A^{-1})}##
sorry i did not know that 1 got cut off I meant why can we assume that the det(A)=det(ainverse)
Also would you agree that my proof is correct?
In this case, the two determinants are the same. But in general, they are not. There's a relation between the determinant of ##A## and ##A^{-1}##, and I'll let you figure out what that is. You have probably seen it already.
You'll understand your proof more once you figure out that.
Only relationship I know that involves A and Ainverse is that (A-1)-1 =A
is that the path you're leading me to?
det(AB) = det(A)det(B). What does this tell you if you put B = A-1?
We would get det(A*A^-1) which equals 1
Yes, it equals 1 but more importantly, you can split the det(A*A^-1) as jubunniii suggested.
Still pretty confused on how that would show that the adj(adj(A))=A
Where would that relationship help with the proof?
Right now I know det(A)=1
1.A-1=adj(A)/det(A)
and 2. A=adj(A-1)/det(A-1)
From 1 and 2 I get A-1=adj(A)
and A=adj(A-1)
Here is where I get completely lost.
Try manipulating the A^-1 and A formulas involving the adjoint in note #2 of the 2nd post in this thread. Then, take the adjoint of both sides of one formula and use the other formula to conclude that adj(adj(A)) = A. Remember that you're given det(A) = 1 which makes both formulas simple.
I figured it out, it was pretty obvious haha what had to be done. Thanks
